Author Topic: Not sure about updated search function  (Read 1066 times)
ChuckInDodgeville
« on: September 14, 2017, 08:31:23 pm »
Is there a setting to restore the way the search function worked in SE 17?  For instance, I would often set it to list and highlight all occurrences.  Now it seems that I have to select this mode very time and it always defaults to finding the next.  This is painful when searching the entire workspace.
Re: Not sure about updated search function
« Reply #1 on: September 15, 2017, 01:20:03 pm »
Are you referring to the Find and Replace Tool Window found in v17?  You can go back to using the Find and Replace Tool window by going to  Options > Editing > Search > Additional options > Default Find and Replace GUI and set it from Mini to Tool Window.
ChuckInDodgeville
« Reply #2 on: September 15, 2017, 01:29:46 pm »
Thank you, that's perfect.
