Author Topic: XML Defs context menu  (Read 1153 times)
  • Hero Points: 191
« on: September 25, 2017, 06:03:22 pm »
I installed RC1 clean, then imported all my old options.
I opened user.cfg.xml.
Right click in the Defs window for the context menu.
The top item in the menu is blank.
It should be "delete attribute" and does delete, but it is blank.
Also note that the Defs window has the age-old problem of narrow columns that do not auto-fix themselves.
If I change the width of the Defs tool window then the columns fix themselves.
See also: https://community.slickedit.com/index.php/topic,15146.0.html
  • Hero Points: 458
Re: XML Defs context menu
« Reply #1 on: September 25, 2017, 06:21:13 pm »
Reproduced. Top item is blank. Thanks for posting.
  • Hero Points: 459
« Reply #2 on: September 26, 2017, 06:02:17 pm »
Fixed for the next drop.
