Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2017 v22 Beta Discussion
Icon sizes in Options 2
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: Icon sizes in Options 2 (Read 3355 times)
Senior Community Member
Hero Points: 210
Text
on:
September 25, 2017, 06:35:32 PM »
Set TabIconSize to extra large.
Close options.
Open Options.
Set TabIconSize to small
See attached.
Logged
Hero Points: 521
Re: Icon sizes in Options 2
Reply #1 on:
September 26, 2017, 04:41:02 PM »
What platform are you seeing this on, and is this a remote display?
And, did you do a fresh clean install, or overlay the beta over a previous installation?
Logged
Hero Points: 210
Text
Reply #2 on:
September 26, 2017, 05:14:23 PM »
Windows 10, local.
Clean install, imported all options exported from Beta3.
Logged
Hero Points: 210
Text
Reply #3 on:
September 26, 2017, 05:21:02 PM »
With a clean configuration I cannot repro.
OTOH, with a clean config setting TabIconSize to extra large results in a horizontal scroller because the area is just a little too small.
Logged
Hero Points: 521
Reply #4 on:
September 26, 2017, 07:14:57 PM »
That is a known issue that I filed under not worth fixing.
Let me know if you have a reproducible case with a clean config, or if I might be able to reproduce it if you gave me your user.cfg.xml.
Logged
Hero Points: 210
Text
Reply #5 on:
September 26, 2017, 08:47:35 PM »
I uploaded it to support: porkka_icon_size
I verified that it repros with this user.cfg.xml file.
Logged
Hero Points: 521
Reply #6 on:
September 27, 2017, 04:45:43 PM »
Reproduced the problem using your configuration. Probably too late for RC2 though, but this will be hot-fixable.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
