Author Topic: SE 2017 Quick Start Fonts panel: set/change size Unicode font  (Read 822 times)
mjdl
  • Hero Points: 16
  • SE 24.0.0.8 hotfix 5 x64 Windows 10 x64 v1909
« on: September 26, 2017, 04:24:55 pm »
Fresh config (RC1 on Win 7 x64).
Quick start Fonts panel.
Initially cannot set size of Unicode font (see attached screenshot) and the font name field is blank.
Need to select different font, then select original choice (i.e. "Default Unicode font (Consolas)" in order for name field to be filled and font size drop-down populated (see attached screenshot).
  • Hero Points: 436
Re: SE 2017 Quick Start Fonts panel: set/change size Unicode font
« Reply #1 on: September 26, 2017, 04:36:34 pm »
Was this a migrated configuration?
What was your Unicode font setting in the previous version?
  • Hero Points: 436
« Reply #2 on: September 26, 2017, 04:37:53 pm »
Never mind, I was able to reproduce the problem.
  • Hero Points: 436
« Reply #3 on: September 26, 2017, 06:02:44 pm »
Fixed for the next drop.
mjdl
  • Hero Points: 16
« Reply #4 on: September 27, 2017, 03:47:24 pm »
A bit late replying to your question re. "fresh config". Yes, this was the initial quick start for an empty configuration folder, I should have been clearer about that.
Glad that this minor fit-and-finish issue will be fixed in RC2.
