Author Topic: How to select correct instance of SlickEdit?  (Read 4998 times)
at5dapa1
  • Hero Points: 24
« on: October 03, 2017, 08:02:09 AM »
From several external log tools I invoke SE to jump to the file-name and line-number (using some regular expressions), so I can see where and why the log was generated.
Sometimes I have 2 instances of SE with 2 projects (a sender and a receiver) and have both logs in the external tool. When I invoke SE it always jumps into the first SE instance, so if I do it from the other log (which should actually go to the second SE) then the first SE will not find the file-name, which is correct.
Is there any way from SE macro (or even dll) level to detect the other SE instances and, if they are, to pass the call to them?
  • Hero Points: 347
Re: How to select correct instance of SlickEdit?
« Reply #1 on: October 03, 2017, 10:30:14 AM »
You might be able to use DDE on Windows - dynamic data exchange.  Have a look at DDE in the help and the command DDE in files.e,  also the editor_name function.  A long time ago I tried using DDE between two slick instances and it worked.  There's also a _list_processes function.
int _list_processes(PROCESS_INFO (&process_list)[]);
You could also do it using one second timer callbacks in each instance of slick that read a particular file to see if there was a new file that should be opened - or something like that.
timer_handle = _set_timer(1000, timer_callback1);
static void timer_callback1()
at5dapa1
  • Hero Points: 24
« Reply #2 on: October 04, 2017, 09:28:29 AM »
Great info! Thanks a lot!
