Author Topic: HighDPI && Multimon && Scaling  (Read 3731 times)
  • Hero Points: 206
« on: October 03, 2017, 02:52:44 pm »
I've got a high DPI laptop with a regular external monitor.
Slick works OK on either display, even moving slick between displays is OK.
But, all Slick UI is scaled according to the monitor that the main Slick UI is on, so a floating tool window on the other monitor is either giant or tiny.
  • Hero Points: 206
Re: HighDPI && Multimon && Scaling
« Reply #1 on: October 03, 2017, 03:04:45 pm »
Odd - maybe this is why I didn't notice before...
Same setup - Slick on highdpi (just for this test. Usually it is on the low dpi external monitor).
When I open list-buffers it appeared on the lowdpi monitor where it normally is -- but it is scaled correctly this time.
As soon as I attempt to drag it it balloons to large size - scaled up like it would be if it was on the highdpi monitor.
