Author Topic: _open_temp_view in the help file needs more info  (Read 1271 times)
  • Hero Points: 322
« on: October 07, 2017, 12:02:30 pm »
The doc comments for _open_temp_view put it in "file functions"  and miscellaneous categories, _create_temp_view is in miscellaneous and _delete_temp_view is in the "selection functions" category.  I suspect the last two should be in the file functions category as well.
The help for _delete_temp_view says the wid passed to it should have come from a call to _create_temp-view - but it could also have come a call to open_temp_view.  The help for open and create should explain that you have to call _delete_temp_view when you're finished with the buffer and that you should also normally restore the window as well, using activate_window.
  • Hero Points: 428
Re: _open_temp_view in the help file needs more info
« Reply #1 on: October 08, 2017, 01:27:14 pm »
Probably too late to get this changed now. Will be changed for the next time we build the docs. Thanks
