Home
Help
Search
Login
Register
SlickEdit Community
Archived Beta Discussions
SlickEdit 201x Beta Discussions
SlickEdit 2017 v22 Beta Discussion
RC4: Local Buffer Find Option Modifies Find GUI, Expected?
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: RC4: Local Buffer Find Option Modifies Find GUI, Expected? (Read 6278 times)
PiezonTM
Senior Community Member
Hero Points: 8
on:
October 12, 2017, 03:11:45 PM »
When I changed the Local Buffer Find (Ctrl-F on a buffer) and change the <All Buffers> setting it also modified the Search/Find... GUI option from <Current Buffer> to <All Buffers>. Is this the expected behavior? Seems odd that these two different search options/features are tied together.
Logged
SlickEdit Team Member
Hero Points: 130
Re: RC4: Local Buffer Find Option Modifies Find GUI, Expected?
Reply #1 on:
October 12, 2017, 03:20:09 PM »
If you make changes to an option in either Mini Find or Tool Find & Replace window, the settings are mirrored and replicated in both. That is a new behavior to v22.
Logged
PiezonTM
Hero Points: 8
Reply #2 on:
October 12, 2017, 04:03:28 PM »
I find feel the mini find feels more like a buffer search--but not limited to it. Would be nice to have the option to treat the separate.
Regardless, thanks for the quick feedback. I'll just have to get used to it. Thanks again.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
