Author Topic: Using name_info  (Read 5171 times)
StephenW
  • Hero Points: 21
Using name_info
« on: May 24, 2007, 12:07:07 am »
I do not understand the syntax for using name_info on a function.  For example, this compiles OK:
_command void test2(int message_number = 0, _str message_text = '') name_info(','VSARG2_MACRO) {
   message(message_number' 'message_text);
But this version does not:
It gives an error message "Expecting '{'" and puts the cursor after the 'f' in name_info.  The only difference is whitespace, so why the problem?
This one, however, does work:
As does this one, without name_info:
This example code, from the V12.0.1 help file (in the "name_info Attributes" section), also does not compile:
_command void gui_enumerate()
       name_info(','VSARG2_REQUIRES_EDITORCTL|VSARG2_REQUIRES_AB_SELECTION)
