Author Topic: Bug:SlickEdit V22 for windows hang up  (Read 1415 times)
Ciky_Yin
« on: November 10, 2017, 05:02:46 am »
win10,64bit,C/C++,when input /***/ in ".c" file,the slickedit 22 will hang up.for example,if Comments like this:
 fucntion:      APP_led_pmtxt
 input:
 output:
 describe:  send pm txt frame
SlickEdit can't open this and hang up.
kkarino
Re: Bug:SlickEdit V22 for windows hang up
« Reply #1 on: November 10, 2017, 11:22:34 am »
I think that it is the same problem as this.  And there is a DLL for fix.
https://community.slickedit.com/index.php/topic,15826.0.html
Ciky_Yin
« Reply #2 on: November 11, 2017, 01:59:54 am »
It dosen't work.
Ciky_Yin
« Reply #3 on: November 11, 2017, 06:29:30 am »
The problem has been resolved.Think you.
