Author Topic: Can slickedit do "Smart Reference Matching" in source insight?  (Read 1138 times)
wubaochuan
« on: November 11, 2017, 01:34:49 pm »
I like the "Smart Reference Matching" feature in source insight very much. I failed to find such feature in slickedit.
Here is info about this feature:
The Smart Reference Matching option means that the search is context-sensitive; the search results will only contain matches for references to the exact symbol you specify, using the surrounding context.
« Last Edit: November 11, 2017, 01:37:47 pm by wubaochuan »
  • Hero Points: 467
Re: Can slickedit do "Smart Reference Matching" in source insight?
« Reply #1 on: November 12, 2017, 02:07:45 pm »
Use the find refences command. Ctrl+/.
