Author Topic: FTP - Can NOT connect.  (Read 937 times)
tinker123
  • Hero Points: 3
« on: December 11, 2017, 04:55:32 pm »
SlickEdit 2011 (v16.0.3.0 64-bit)
RHEL 6.9
Hi,
I am on RHEL 6.9.  I have no problem connecting to a remote site, via FTP with the Nautilus File Manager (2.28 ).
I can't connect with Visual Slickedit
The error message I am getting
FTP Error
Error with LIST response.
Bad or unexpected response
425 Could not open data connection to port 32801: Connection refused
I am not setting that port,  I have the default port of 21.
I am using the remote directory of "/", which works with the file manager on my OS.  I also tried different directories.  No dice.
I am providing my server name, userid, passoword.  I have tried setting my host type to both Auto and Unix.  No dice.
Any idea what is wrong and how I can fix it?
Thanks
Steve
Rodney
  • Hero Points: 48
Re: FTP - Can NOT connect.
« Reply #1 on: December 11, 2017, 05:12:22 pm »
The LIST command is failing. You need to enable passive data connections. Search the forum for "PASV" and you should find instructions.
++rodney
tinker123
  • Hero Points: 3
« Reply #2 on: December 11, 2017, 05:29:52 pm »
It worked.
Thank You
SlickEdit can work with passive transfers (PASV), but it is not the default. You will have to set it up:
1. File>FTP>Default Options
2. Firewall/Proxy tab
3. Enable firewall/proxy ON
4. Select "Router" (Passive transfers will be forced ON)
Now edit your connection profile:
1. Advanced tab
2. Use firewall/proxy ON
++rodney
