Author Topic: Slow "Find in Files" and Build Startup  (Read 3661 times)
groman
« on: May 24, 2007, 11:38:08 PM »
I am using Slickedit v11 on a fairly large project. I am not sure what I changed but right now starting a "Find in Files" has a 2-3 minute startup time when the UI freezes but no grepping is actually going on. I checked with process explorer to see what files vs.exe was accessing and it was simply opening directories in some part of the project. Same UI freeze happens when I invoke any of the custom project build commands for the currently open project. It seems to just scan folders in other projects in the workspace before it does anything. It was not doing this before and I can't figure out what I changed.
Any suggestions on what might be causing this? It's really frustrating to have to wait several minutes each time I launch a search or a build.
Re: Slow "Find in Files" and Build Startup
« Reply #1 on: May 25, 2007, 01:06:50 PM »
Are you using Foreground search option or defaulting to background searches and are you searching in <Workspace> or <Project>?  I suspect that you have wildcards defined in the project, and it's trying to match all the files that match the wildcard spec in the project in fairly deep or lengthy directory structure, and then has to match with the wildcard spec based on your search parameters.  We have made some improvements to parsing project files in the 12.0.1 release, but even with that, wildcard specs still currently has some performance drawbacks.
