Author Topic: Still seeing text unselect itself  (Read 5116 times)
  • Hero Points: 322
Re: Still seeing text unselect itself
« Reply #15 on: February 24, 2018, 06:38:38 am »
Thanks for the hard work narrowing this down.  This gives me a good starting point as to what code to review.
Won't you be looking for a needle in a haystack?  I wonder whether you could send a debug build to the guy who can reproduce it easily, that had some kind of back tracking built into it so when a selection disappears when it shouldn't, you can capture some data that might tell you the cause.  Or maybe he could ship his computer to you...
  • Hero Points: 438
« Reply #16 on: February 26, 2018, 03:00:47 pm »
If the Current Context toolbar is truly the problem, then it's more of a needle in a small square bale.
Exolon
  • Hero Points: 5
« Reply #17 on: March 01, 2018, 10:08:32 am »
I see this behavior, too, and I did a screen recording (attached).
I had the search mini window open with a search keyword matching the current line (yellow marking). Then I edited the comment above the matching line and then marked the line below the comment. As as a result, the line unselects itself. After pressing undo the selection within the comment unselects itself, too.
If I close the search mini window, the unselect is not happening.
Emulation: CUA
OS Version: Ubuntu 16.04.3 LTS
Language: . (Bourne Shell)
Encoding: Automatic
Kind regards
Exo
« Reply #18 on: March 01, 2018, 02:00:35 pm »
I can definitely reproduce the issue where text is deselected when Mini-Find is active and highlighting matches.  I will file a defect and investigate.  I can't verify if it is the same issue for other reports in this thread, but could be related.
  • Hero Points: 184
« Reply #19 on: September 04, 2018, 04:37:25 pm »
Still happens in V23 Beta 3.
Is there some extra debugging we can do during beta to track this down?
« Reply #20 on: September 04, 2018, 05:54:07 pm »
A fix was checked in to handle the case with Mini-Find highlighting removing selections.  That was the only reproducible case we had at the time.  We'll need to start over, do you think it is related to Mini-Find or Tool Find or is searching not even related to what you are seeing?
  • Hero Points: 184
« Reply #21 on: September 04, 2018, 06:06:55 pm »
Not related to mini find as I don't use that, nor do I use the find tool bar.
Exolon
  • Hero Points: 5
« Reply #22 on: September 05, 2018, 08:13:45 am »
I have strange selection behavior in 2018 Beta 3, too.
If I select a region with the mouse and switch to another window (e.g. terminal), the selection changes to something completely different.
Please see screen recording attached.
OS: Ubuntu 16.04.5 LTS
  • Hero Points: 421
« Reply #23 on: September 05, 2018, 09:32:08 pm »
I can't seem to reproduce this. However, I can't tell what you're clicking on. I tried clicking on a Terminal window like you say in your explanation. Does this reproduce for you with a default config (vs +new -sc /tmp/newconfigdir).
Exolon
  • Hero Points: 5
« Reply #24 on: September 06, 2018, 05:46:36 am »
Yes, it is reproducible with a fresh VS 2018 Beta 3 configuration.
It does not matter what I'm clicking (e.g. desktop, terminal, browser, etc.) as long I click on the right side of my VS window. It does not happen if I click on the left side of SlickEdit.
The Problem is not reproducible if I turn off the minimap.
  • Hero Points: 421
« Reply #25 on: September 06, 2018, 01:00:31 pm »
Are you clicking in the minimap window or to the right of the minimap window (shell window frame)?
Exolon
  • Hero Points: 5
« Reply #26 on: September 06, 2018, 01:19:31 pm »
No, I'm clicking on the desktop or into a terminal on the right, outside of the SE window.
  • Hero Points: 421
« Reply #27 on: September 06, 2018, 03:51:07 pm »
Got it to happen now. Not sure why it wouldn't repro before.
  • Hero Points: 421
« Reply #28 on: September 06, 2018, 04:20:02 pm »
Fixed in beta 4
