Author Topic: "Return" inserts new line below current line?  (Read 1095 times)
rgloden
  • Hero Points: 5
« on: February 23, 2018, 04:28:20 am »
SlickEdit Pro 2016 (v21.0.3.0 64-bit)
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Project Type: Cpp
Language: .adb (Ada)
Using the following Ada sample, place cursor at beginning of buffer, hit enter, and SE inserts a new line below the first line (expected <CR> inserted before first line instead of after).
package body time_helper is
   procedure get_time;
end time_helper;
Results:
   procedure get_time;
end time_helper;
  • Hero Points: 458
Re: "Return" inserts new line below current line?
« Reply #1 on: February 23, 2018, 04:24:05 pm »
Added a hot fix for this for v22. Will be in the next hot fix build.
rgloden
  • Hero Points: 5
« Reply #2 on: March 14, 2018, 04:58:19 am »
Thanks ... Hotfix works.
