Author Topic: Tool window pins toggle  (Read 1032 times)
  • Hero Points: 183
« on: March 04, 2018, 11:51:00 pm »
I'd like a quick and easy way to pin & unpin all visible, docked toolwindows.
Sortof like full screen, but just a quick way to get rid of all the docked toolwindows so I can have more editor space.
I normally do not like unpinned & docked tool windows, but sometimes when I'm just using a small screen it would be great to quickly switch all those docked tool windows off.
This would not change the size or position of the main slick window at all, just the docked tool windows.
  • Hero Points: 320
Re: Tool window pins toggle
« Reply #1 on: March 05, 2018, 01:46:39 am »
You might be able to use  xsave_named_toolwindow_layout  here.
https://community.slickedit.com/index.php/topic,11186.0.html
It would be good if slickedit could support this properly.
Slickedit has save_named_state and load_named_state already but they're undocumented.
