Author Topic: Search results make filename visible  (Read 950 times)
  • Hero Points: 325
« on: April 28, 2018, 08:30:10 am »
In the search results window, a filename is shown prefixed with its path.  With long pathnames, the actual filename (minus path) isn't visible (for me).  I would like the filename part to come before the path (as well as at the end) so I can see it, regardless of the length of the path.   e.g. File abc.d  c:\some\long\path\abc.d
