Author Topic: pico style  (Read 1510 times)
RaffoPazzo
pico style
« on: May 11, 2018, 11:56:36 am »
Hi, I came across code using pico style, eg:
void foo()
{   bar();
    if (check)
    {    bar();
    else
void func()
Is there a way/plan to support it?
  • Hero Points: 467
Re: pico style
« Reply #1 on: May 11, 2018, 01:48:40 pm »
No plan to support it yet.
RaffoPazzo
Re: pico style
« Reply #2 on: March 19, 2019, 07:52:48 am »
Is there a way I can write it myself via slick-C or something?
  • Hero Points: 334
Re: pico style
« Reply #3 on: March 19, 2019, 10:52:13 am »
"Artistic style" appears to support it
http://astyle.sourceforge.net/astyle.html#_style=pico
You can write a macro to enter braces and bind it to {
_command void pico_brace() name_info(','VSARG2_MULTI_CURSOR|VSARG2_REQUIRES_EDITORCTL|VSARG2_CMDLINE)
   _insert_text("{   }");
   cursor_left();
   cursor_left();
   cursor_left();
For C/C++, the "{" character is bound to c_begin.
RaffoPazzo
Re: pico style
« Reply #4 on: May 17, 2019, 10:44:07 am »
Looking at all the formatting settings avaiable, it seems you only need a couple more, eg "Break line after {", "Number of spaces after {", "Keep } on same line", etc. In principle it sounds like something simple to add for you guys :)
