Author Topic: Configuring mingw project in v22.0.2.1  (Read 9721 times)
bremenpl
  • Electrical Engineer
« on: May 22, 2018, 04:32:02 am »
Hello there,
I started using Slickedit back in 2013 and last time I used it was in 2014. I tried to like it more but it was simply to complicated to setup as an IDE, thus, to expensive to use only as an alternative to Notepad++ for viewing files.
Yesterday I decided to give it another shot, since some years passed by. Thought maybe it improved, maybe I will know how to set it up faster since im doing my job for a longer amount of time now. And again, I cannot set up a simple mingw c project on Windows platform... Maybe I dont get it but i is just so much simplier in Eclipse. I tried to use this blog post: https://www.youtube.com/watch?v=njXbtrW3-po but the context menus are out of date already. And this is just the compiler step, i will have to setup the debugger as well.
My question is: Is there any up to date, step-by-step guide on what to do in order to setup a c compiler in Slickedit v22.0.2.1? I would appreciate all help.
  • Hero Points: 153
Re: Configuring mingw project in v22.0.2.1
« Reply #1 on: May 22, 2018, 11:58:35 am »
Sorry this isn't more obvious, but it's fairly simple to make it work.
  • Be sure g++ is in your path
  • Use the project wizard(s) for GNU C/C++
  • Go to Debug>Debugger Options>Configurations.  There should be an entry there for the MinGW debugger already (if not let me know).  Select it and click "Default native debugging configurations".
bremenpl
« Reply #2 on: May 22, 2018, 03:07:20 pm »
Hi, thanks for answer. Yes, thats another thing. Is there a way to define the g++ (and all other programs) manually so it doesnt have to be set in PATH?
  • Hero Points: 153
« Reply #3 on: May 22, 2018, 03:09:52 pm »
Yes.  Go to Build>GNU C Options and it's on the Compile tab toward the bottom.  There's another on the Link tab.  We already talked about the debugger configuration in the previous post.
bremenpl
« Reply #4 on: May 22, 2018, 03:29:55 pm »
I had to change the default slashes from "\" to "/" because the program did not recognize them. At the moment trying to compile hello world. The Pathes seems ok but still:
K: & cd K:\testowy
K:\testowy>echo VSLICKERRORPATH="K:\testowy"
K:\testowy>"C:\Program Files\SlickEdit Pro 22.0.2\win\vsbuild" -signal 56182 -command make -f "K:\testowy\test2.mak" CFG=Debug
make -f K:\testowy\test2.mak CFG=Debug
C:/MinGW/bin/gcc.exe -c   -g3 -ggdb -p -pg -o "Debug/test2.o"  test2.c
make: *** [Debug/test2.o] Error 1
K:\testowy>
Any idea what could be left there to set?
  • Hero Points: 153
« Reply #5 on: May 22, 2018, 03:32:34 pm »
Did you choose build with a SlickEdit maintained makefile?  Or did you have this makefile already?
bremenpl
« Reply #6 on: May 22, 2018, 03:35:44 pm »
I choose for slickedit to maintain makefile.
  • Hero Points: 153
« Reply #7 on: May 23, 2018, 01:23:20 pm »
OK.  Can you send me or attach the makefile?  Maybe we're doing something in there that GNU supports that MinGW's make doesn't (or maybe there's a bug with that option).
bremenpl
« Reply #8 on: May 23, 2018, 05:34:54 pm »
Sure thing, here it is:
# SlickEdit generated file.  Do not edit this file except in designated areas.
# Make command to use for dependencies
MAKE=make
RM=rm
MKDIR=mkdir
# -----Begin user-editable area-----
# -----End user-editable area-----
# If no configuration is specified, "Debug" will be used
ifndef CFG
CFG=Debug
endif
# Configuration: Debug
ifeq "$(CFG)" "Debug"
OUTDIR=Debug
OUTFILE=$(OUTDIR)/test.exe
CFG_INC=
CFG_LIB=
CFG_OBJ=
COMMON_OBJ=$(OUTDIR)/test.o
OBJ=$(COMMON_OBJ) $(CFG_OBJ)
ALL_OBJ=$(OUTDIR)/test.o
COMPILE=C:/MinGW/bin/gcc.exe -c   -O0 -g3 -ggdb -p -pg -o "$(OUTDIR)/$(*F).o" $(CFG_INC) $<
LINK=C:/MinGW/bin/gcc.exe  -O0 -g3 -ggdb -p -pg -o "$(OUTFILE)" $(ALL_OBJ)
COMPILE_ADA=gnat -g -c -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_ADB=gnat -g -c -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_F=gfortran -c -g -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_F90=gfortran -c -g -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_D=gdc -c -g -o "$(OUTDIR)/$(*F).o" "$<"
# Pattern rules
$(OUTDIR)/%.o : %.c
$(COMPILE)
$(OUTDIR)/%.o : %.ada
$(COMPILE_ADA)
$(OUTDIR)/%.o : %.d
$(COMPILE_D)
$(OUTDIR)/%.o : %.adb
$(COMPILE_ADB)
$(OUTDIR)/%.o : %.f90
$(COMPILE_F90)
$(OUTDIR)/%.o : %.f
$(COMPILE_F)
# Build rules
all: $(OUTFILE)
$(OUTFILE): $(OUTDIR) $(OBJ)
$(LINK)
$(OUTDIR):
$(MKDIR) -p "$(OUTDIR)"
# Rebuild this project
rebuild: cleanall all
# Clean this project
clean:
$(RM) -f $(OUTFILE)
$(RM) -f $(OBJ)
# Clean this project and all dependencies
cleanall: clean
endif
# Configuration: Release
ifeq "$(CFG)" "Release"
OUTDIR=Release
CFG_INC=
CFG_LIB=
CFG_OBJ=
COMPILE=gcc -c   -o "$(OUTDIR)/$(*F).o" $(CFG_INC) $<
LINK=gcc  -o "$(OUTFILE)" $(ALL_OBJ)
COMPILE_ADA=gnat -O -c -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_ADB=gnat -O -c -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_F=gfortran -O -g -o "$(OUTDIR)/$(*F).o" "$<"
COMPILE_F90=gfortran -O -g -o "$(OUTDIR)/$(*F).o" "$<"
# Pattern rules
$(OUTDIR)/%.o : %.c
$(COMPILE)
$(COMPILE_ADA)
$(OUTDIR)/%.o : %.d
$(COMPILE_D)
$(COMPILE_ADB)
$(COMPILE_F90)
$(OUTDIR)/%.o : %.f
$(COMPILE_F)
# Build rules
all: $(OUTFILE)
$(LINK)
$(OUTDIR):
clean:
$(RM) -f $(OUTFILE)
$(RM) -f $(OBJ)
cleanall: clean
endif
  • Hero Points: 153
« Reply #9 on: May 23, 2018, 06:36:15 pm »
I can't reproduce that problem.  Are your project files in one directory?  Are they in the same directory as the .vpj file, or a relative path?
bremenpl
« Reply #10 on: May 23, 2018, 06:47:31 pm »
Yes, its a single hello world file:
k:\test>dir
 Wolumin w stacji K to RAMDISK
 Numer seryjny woluminu: 0E17-3000
 Katalog: k:\test
2018-05-23  19:36    <DIR>          .
2018-05-23  19:36    <DIR>          ..
2018-05-23  19:36               199 test.vpw
2018-05-23  19:38               112 test.vpwhist
2018-05-23  19:38             7 372 test.vpj
2018-05-23  19:36               105 test.c
2018-05-23  19:39           147 456 test.vtg
2018-05-23  19:38             2 669 test.mak
2018-05-23  19:37    <DIR>          Debug
               6 plik(ów)            157 913 bajtów
               3 katalog(ów)   2 135 937 024 bajtów wolnych
k:\test>
bremenpl
« Reply #11 on: May 23, 2018, 07:14:00 pm »
Its odd, because if I execute the make line manually:
C:/MinGW/bin/gcc.exe  -O0 -g3 -ggdb -p -pg -o "Debug/test.exe" Debug/test.o
It compiles. The make does not work:
k:\test>make -f test.mak CFG=Debug
C:/MinGW/bin/gcc.exe -c   -O0 -g3 -ggdb -p -pg -o "Debug/test.o"  test.c
gcc.exe: fatal error: no input files
compilation terminated.
make: *** [Debug/test.exe] Error 1
« Last Edit: May 23, 2018, 07:17:01 pm by bremenpl »
  • Hero Points: 153
« Reply #12 on: May 23, 2018, 07:16:17 pm »
I wonder if it is the slashes.  I didn't change mine.
bremenpl
« Reply #13 on: May 23, 2018, 07:17:36 pm »
But I can copy those gcc lines and execute in terminal and they work.
Also the lib part works:
The output generation does not:
  • Hero Points: 153
« Reply #14 on: May 23, 2018, 07:23:00 pm »
What if you use g++ rather than gcc?
