Author Topic: Installing hotfix resets auto update option  (Read 687 times)
Nosh
« on: June 24, 2018, 03:38:08 pm »
Every time I install a hotfix "Help->Product Updates->Load Hot Fix..." the "Automatically check for updates" option is reset to "Once per day".
Is this intentionally or a bug?
Regards, Norbert
Nosh
Re: Installing hotfix resets auto update option
« Reply #1 on: July 13, 2018, 11:31:45 am »
No comment?
Rodney
  • Hero Points: 47
« Reply #2 on: July 26, 2018, 07:13:35 pm »
Reproduced. The setting is getting overridden by the AutoUpdate setting in 'Admin.xml' in the root installation folder (e.g. c:\program files\SlickEdit Pro 22.0.2). Edit the file (you will need Administrator/root rights) and set check="0" on the AutoUpdate element.
++rodney
Rodney
  • Hero Points: 47
« Reply #3 on: July 30, 2018, 07:37:59 pm »
This issue is addressed in the next release (in beta now). Thanks for the report.
++rodney
Nosh
« Reply #4 on: August 26, 2018, 03:45:18 pm »
Thank you, Rodney! Will check when the first V23 hotfix arrives.
Regards, Norbert
