Author Topic: Disable Menu Bar & Document Tabs  (Read 327 times)
weswitt
« on: June 26, 2018, 06:09:36 pm »
Is there a way to disable (remove) the menu bar and then access is with just the ALT key?
Is there a way to remove the document tabs so they are not displayed?
  • Hero Points: 370
Re: Disable Menu Bar & Document Tabs
« Reply #1 on: June 27, 2018, 08:48:28 pm »
Window>Zoom Toggle will expand the current window and hide the tabs. I use this a lot.
Currently, only full screen mode (View>Full Screen) removes the menu bar on Mac. On windows, only the title bar is removed.
