Home
Help
Search
Login
Register
SlickEdit Community
SlickEdit Product Discussion
SlickEdit®
how to disable source control prompts
« previous
next »
Print
Pages: [
1
Go Down
Author
Topic: how to disable source control prompts (Read 776 times)
IkerAriz
Senior Community Member
Hero Points: 6
on:
June 29, 2018, 02:30:41 pm »
Is there any way to disable the source control prompts when adding/removing project files?
Iker
Logged
Hero Points: 325
Re: how to disable source control prompts
Reply #1 on:
June 29, 2018, 11:48:36 pm »
What is the prompt that comes up? If you search slickedit macro sources for the text string, you might be able to see how to disable the prompt.
Logged
Print
Pages: [
1
Go Up
« previous
next »
SlickEdit Community
SlickEdit®
