Author Topic: vtg not retained in profile  (Read 751 times)
bbcorp
« on: July 10, 2018, 06:21:21 pm »
I am a long time user of SlickEdit with a new problem.
I have recently re-installed SlickEdit Pro 2017 (v22.0.2.1 64-bit) to a new desktop running Windows 10 Home.
SlickEdit is being used with a C code project.
I have successfully created a new C/C++ tag file.
I see the newly tagged files in the File list: pane of the Context Tagging window.  I see the tag file in the Tag files: list pane of the Context Tagging window.  The .vtg file is created and saved in C:\Users\User\Documents\My SlickEdit Config\22.0.2\tagfiles
If I select "Done", the Context Tagging window closes.
If I return to the Context Tagging window, the Tag file is not listed in the pane.  I can re-add it via Add Tag File... but it will never save.
What causes this problem?
  • Hero Points: 440
Re: vtg not retained in profile
« Reply #1 on: July 10, 2018, 09:11:51 pm »
There was a fix relating to this in a recent hot fix, do you have the latest hot fixes for 22.0.2 ?
bbcorp
« Reply #2 on: July 12, 2018, 08:32:33 pm »
This hotfix fixed the problem.
Thanks for the recommendation.
I am running a single-user install and license.
No worries.
BR
