Author Topic: Search "Find and Replace" is missing "Look in:" <Workspace> and <Project>  (Read 582 times)
AtticMan
Hi,
I have no idea why this is not working anymore. I remember this used to work where I could search and select look in <Workspace> or <Project> for only files I have in my project, not every file in the directory. I had to resort to "Search Files" which searches the entire Linux Kernel source tree for /arch/... devices I don't even care about giving me an overwhelming return and useless list.
I am using SlickEdit Version 15.0.1.3. I was going to upgrade so I can work seamlessly with VS2017 but not sure if this will have same lacking behavior.
In versions prior to 21.0.x, <Workspace> and <Project> are only listed in Look in drop-down for Find in Files tab.   The only other requirement that there must be an open workspace and project.
AtticMan
Yes! Thank you. I know I was able to do this with my old dev system and could have sworn it was under, "Find" in the "Find and Replace" pop-up.
