Author Topic: Patch 11.0.1 problem: tag file uslickc.tag not found.  (Read 4238 times)
NightStorm
« on: July 20, 2006, 06:49:49 pm »
I'm seeing this message:
  Tag file '/path/to/home/.slickedit/11.0.1/tagfiles/uslickc.vtg' not
  found
               [OK]
The above will be output twice each time I start VSt.  Two clicks on the "Ok" and I'm back to the main window.
I've tried:
  - Removing my .slickedit/11.0.1 directory and rerunning slickedit to let it recreate it from the old .slickedit/11.0.0 directory
  - Tools->Tag files .. and deleting the "Slick-C" Tag Files reference
Neither makes any difference .. the message always comes back.
The file *does* exist under the 11.0.0/tagfiles directory.  Perhaps I should just copy it over.
openSUSE Linux 10.1 btw
  • Hero Points: 434
Re: Patch 11.0.1 problem: tag file uslickc.tag not found.
« Reply #1 on: July 21, 2006, 01:07:52 pm »
Here is a quick workaround for your 11.0.1.
Go to Tools > Tag Files..., select "Slick-C Tag Files", you should see uslickc.vtg there, probably with a gray icon (because the file is missing).  Click on "Remove Tag File".  That should take care of it.
