Author Topic: corrupted character in japanese  (Read 1033 times)
kkarino
« on: July 20, 2018, 08:24:09 am »
Japanese characters are partially broken and displayed.
SlickEdit Pro 2017 (v22.0.2.1 64-bit)
Serial number:
License file: C:\ProgramData\slickedit\22\slickedit.lic
Build Date: July 12, 2018
Emulation: Vim
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 70% Load, 5763MB/8191MB Physical, 19812MB/23064MB Page File, 476MB/134217727MB Virtual
Screen Size: 2560 x 1080, 2560 x 1440
Language: .txt (txt)
Encoding: Automatic
Installation Directory: D:\SlickEdit Pro 22.0.2\ (non-removable drive,NTFS,35076MB free)
Configuration Directory: L:\Test_SlickEdit\temp_Config2\22.0.2\ (non-removable drive,NTFS,41349MB free)
Hotfixes:
L:\Test_SlickEdit\temp_Config2\22.0.2\hotfixes\hotfix_se2202_11_cumulative.zip (Revision: 11)
  • Hero Points: 417
Re: corrupted character in japanese
« Reply #1 on: July 21, 2018, 03:48:26 pm »
No Japanese characters are displayed after I import your settings. Attached is the picture. This is correct operation due that fact that it's been disabled. The "Use fixed spacing for bold and italic fixed Unicode fonts" option disables all unicode support. Definitely don't use this option. You'll need to check the "Fixed Fonts Only" check box to enable this check box.  Tools>Options>Appearance>Fonts.
Once I turned this setting off, then all the Japanese characters displayed fine for me. Attached is a picture. Judging from your picture, your settings are different than what you've posted.
kkarino
« Reply #2 on: July 21, 2018, 09:13:21 pm »
Re posted Option file with setting capture.
My Font Setting : MS-Gothic.
  • Hero Points: 417
« Reply #3 on: July 21, 2018, 10:20:45 pm »
I got all question marks because I'm in a different active code page. I'll try 932 which is Japanese.
  • Hero Points: 417
« Reply #4 on: July 21, 2018, 10:39:32 pm »
Reproduced when I'm using codepage 932. Seems to only happen with DBCS (active code page is DBCS) and not Unicode. However, with the option you're using, there's no such thing as pure Unicode display anymore.
If you turn off the "Use fixed spacing for bold and italic fixed Unicode fonts" and restart, the test_UTF-8.txt file will display correctly. However, the other file will still not work.
We will look into this.
  • Hero Points: 417
« Reply #5 on: July 21, 2018, 10:48:46 pm »
Thanks for the nice test cases. Easy to fix. We'll build a replacement vsapi.dll and get it to you this week.
kkarino
« Reply #6 on: July 22, 2018, 05:33:06 am »
Thank you Clark.
Yes, The Unicode file is now correct with this setting.
SlickEdit Support
  • Hero Points: 26
« Reply #7 on: July 23, 2018, 12:13:45 am »
PM sent.
SlickEdit Support
kkarino
« Reply #8 on: July 23, 2018, 11:04:00 am »
Thank you, Clark.
All have been fixed.
