Author Topic: Project>Properties>Open Not exiting vim command mode for new text  (Read 715 times)
b
  • Hero Points: 26
This is the first time I'd really had a need to use this Window to adjust my environment for the project.  Although I was greeted with the expected vim oriented editor, I found that it never exited command mode to actually type in any new text.  I can paste, delete, navigate, but can't seem to insert (I/i), or append (A/a), or open a new line (O/o).  Although, it is interesting that the latter does create a new line (above or below), but any subsequent characters typed are ex commands, not new text.
SlickEdit Pro 2017 (v22.0.2.1 64-bit)
Serial number: FE10297
License file: C:\ProgramData\slickedit\22\slickedit.lic
Build Date: February 12, 2018
Emulation: Vim
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 49% Load, 8020MB/16265MB Physical, 11722MB/32530MB Page File, 6909MB/134217727MB Virtual
Screen Size: 1200 x 1920
Project Type: Gnuc
Language: .process (Process)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 22.0.2\ (non-removable drive,NTFS,40442MB free)
Configuration Directory: C:\Users\bkurle\Work Folders\Documents\My SlickEdit Config\22.0.2\ (non-removable drive,NTFS,40442MB free)
b
  • Hero Points: 26
Re: Project>Properties>Open Not exiting vim command mode for new text
« Reply #1 on: July 23, 2018, 07:39:58 pm »
I thought I had the latest Hotfix, and apparently I did not.  Loaded hotfix 11 and see that this problem was fixed.
