Author Topic: SlickEdit calls IAR to compile code error  (Read 1441 times)
Ciky_Yin
« on: July 28, 2018, 05:25:10 am »
I want to use SlickEdit to call IAR's IarBuild.exe to compile the code, but he doesn't work.The specific error is as follows:
C:\Users\admin\Desktop\IAR\projects\HT6025>echo VSLICKERRORPATH="C:\Users\admin\Desktop\IAR\projects\HT6025"
"C:\Program Files\SlickEdit Pro 22.0.1\win\vsbuild" -signal 50007 -command C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\common\bin\IarBuild Project.ewp -make Debug
C:\Users\admin\Desktop\IAR\projects\HT6025> VSLICKERRORPATH="C:\Users\admin\Desktop\IAR\projects\HT6025"
vsbuild: File not found (C:\Program)
How can I solve this problem, thank you!
  • Hero Points: 330
Re: SlickEdit calls IAR to compile code error
« Reply #1 on: July 29, 2018, 05:31:59 am »
You probably need to put quotes around this
"C:\Program Files (x86)\IAR Systems\Embedded Workbench 7.2\common\bin\IarBuild"
