Author Topic: Change Selective Display icon color? v22.0.2.1  (Read 1229 times)
JimmieC
  • Hero Points: 16
« on: July 31, 2018, 05:13:55 pm »
How do I change the color of the Selective Display expansion controls in the left-side column. I did look in Tools->Options->Appearance->Colors but could figure out which entry controlled it. See attached jpg.
  • Hero Points: 440
Re: Change Selective Display icon color? v22.0.2.1
« Reply #1 on: July 31, 2018, 05:35:07 pm »
Sorry, those colors are not configurable (since the colors are built into the icon set).
JimmieC
  • Hero Points: 16
« Reply #2 on: July 31, 2018, 05:45:25 pm »
That's too bad. With the color scheme I'm using, these icons are hard to see. The contrast to too subtle.
I like the black background. I will see if there is another color scheme I can use.
  • Hero Points: 440
« Reply #3 on: July 31, 2018, 05:52:01 pm »
What you may need to adjust is the Line Prefix Area background color.  I use RGB(32,32,32)
« Last Edit: July 31, 2018, 05:55:03 pm by Dennis »
JimmieC
  • Hero Points: 16
« Reply #4 on: July 31, 2018, 07:47:35 pm »
Thanks Dennis.
I was actually wanting to change the icon color due to contrast. And when I said that I liked the black background, I was referring to the edit area. But, yeah, black\dark in the Line Prefix area works (now I know that it is called Line Prefix). I am still not crazy about the icon color, but the main issue for me was the contrast. I really couldn't see it well (mild color-blindness I guess). So this solves it and I like the black\dark Line Prefix area.
