Author Topic: Minimap off by default?  (Read 3306 times)
jc44
  • Hero Points: 22
« on: August 01, 2018, 11:45:22 am »
Can I turn the minimap off by default?  It seems to turn up every time I open a file that I haven't opened before.  It is a cute feature but normally I want its width.
Thanks
  • Hero Points: 153
Re: Minimap off by default?
« Reply #1 on: August 01, 2018, 01:26:26 pm »
Go to Tools>Options.  You can then select a particular language or all languages.  It is in the View category (Show minimap).
jc44
  • Hero Points: 22
« Reply #2 on: August 01, 2018, 01:41:48 pm »
Ah! Thanks. I could have sworn I'd looked there, but obviously not.
  • Hero Points: 509
« Reply #3 on: August 01, 2018, 04:59:43 pm »
You can also turn it off when you go through Quick Start Configuration wizard.  You'll find it at the top of the "Fonts" page.
  • Hero Points: 507
« Reply #4 on: August 02, 2018, 09:25:03 pm »
You can also turn off the minimap here (Options>Languages>All Languages>View>Show minimap). It's good to know about All Languages because it can help with changing other settings in a global way.
Marcel
  • Hero Points: 26
« Reply #5 on: August 03, 2018, 03:15:34 am »
I turned the minimap off for all languages, but this didn't clear the map for files that had been opened (and possibly closed) before I toggled the setting. There must be a sticky per-file flag somewhere.
guth
  • Hero Points: 7
« Reply #6 on: August 03, 2018, 05:57:10 am »
I think I had to restart slick for the setting to take.
  • Hero Points: 507
« Reply #7 on: August 03, 2018, 12:42:24 pm »
We will fix that. Thanks for lettings us know.
