Author Topic: Adding/Deleting file from .sln project causes crash  (Read 921 times)
Robert Hall
  • Hero Points: 3
« on: August 08, 2018, 09:04:51 pm »
I right click on the projects pane.
As I curson over to Add... SlickEdit disappears.
If I try to delete a file from the .sln file, I either get a crash or a stack dump.
If I try to Remove a file from the properties window I either get a hang, or I get "Invalid argument file=wkspace.ex offset=778
from the stack window:
 Invalid argument
wkspace.ex 778 _AbsoluteToWor"D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software
Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software
Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs""D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Advanced.xaml.cs"kspace(<empty>,D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\Remote Commissioning.sln)
p_window_id: 431 p_object: OI_EDITOR p_name: tags.ex 5218 project_tags_filename_only(<empty>,0) p_window_id: 421 p_object: OI_COMMAND_BUTTON p_name: _ok tagform.ex 8516 tag_add_viewlist(D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\Remote
Commissioning.vtg,427,<empty>,0,1,1) p_window_id: 421 p_object: OI_COMMAND_BUTTON   p_name: _ok makefile.ex 12520 makefile:WriteVisualStudioStandardProjectFile2005(D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote
Commissioning.csproj,CSHARP,cs,428,431,12,1,1)
   p_window_id: 421
   p_name: _ok
makefile.ex 11017 makefile:WriteVisualStudioStandardProjectFile2(D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote Commissioning.csproj,CSHARP,cs,428,431,12,1,1)
   p_window_id: 421
   p_name: _ok
makefile.ex 10801 makefile:WriteVisualStudioStandardProjectFile(431,D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote Commissioning.csproj,.csproj)
   p_window_id: 421
   p_name: _ok
makefile.ex 7501 SaveAssociatedProjectFiles(431,D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote Commissioning.vpj)   p_window_id: 421   p_object: OI_COMMAND_BUTTON   p_name: _ok
project.ex 49085 project:save_source_filenames(279)   p_window_id: 421   p_object: OI_COMMAND_BUTTON   p_name: _ok
project.ex 41646 project:okFiles(1)   p_window_id: 421   p_object: OI_COMMAND_BUTTON   p_name: _ok
project.ex 44167 project:doOK()   p_window_id: 421   p_object: OI_COMMAND_BUTTON   p_name: _ok
project.ex 43872 _project_form._ok.lbutton_up()   p_window_id: 279   p_object: OI_FORM   p_name: _project_form
dlgeditv.ex 7316 show(-mdi -modal -xy _project_form,D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote Commissioning.vpj,3,,1,1,0,0)   p_window_id: 106   p_object: OI_EDITOR   p_name:
project.ex 600 project:project_edit2(,D:\D Software Projects\Navigan_v_2_0_1_0\SourceCode\WPFPageSwitch\Remote Commissioning.vpj,0)   p_window_id: 106   p_object: OI_EDITOR   p_name:
project.ex 812 project_edit(,0)   p_window_id: 106   p_object: OI_EDITOR   p_name:
Re: Adding/Deleting file from .sln project causes crash
« Reply #1 on: August 09, 2018, 01:59:48 pm »
Thanks for the sample, reproduced.  Working on a fix for this.
Robert Hall
  • Hero Points: 3
« Reply #2 on: August 09, 2018, 02:10:27 pm »
Excellent
