Author Topic: 'activate-files' doesn't focus the filter control  (Read 3232 times)
  • Hero Points: 288
« on: June 01, 2007, 12:55:32 pm »
@SlickTeam:
Please add the functionality to put the focus to the filter control also for 'activate-files'.
BTW: I implemented a (hs2_)switch_filelist fct. to cycle thru the diff. listing modes with keys.
I'm using it now also as workaround for the focus problem.
For those who are interested in it I attach it as a separate module (requires SE v12.0.1).
  • Hero Points: 288
Re: 'activate-files' doesn't focus the filter control
« Reply #1 on: July 06, 2007, 05:42:43 pm »
I'd like to bump this request.
I'm now using the Filelist TB instead of my legacy stuff and this issue is really a bit annoying if one doesn't use the mouse very often.
Please have a look at it, although my patch is working well. So it's not that urgent (for me) ;)
