Author Topic: Old bug: Selections and Highlight symbol under cursor  (Read 822 times)
  • Hero Points: 184
« on: August 09, 2018, 12:01:23 am »
Highlight symbol under mouse has rendering precedence over selection - making the selection invisible.
Enable that, place the cursor inside a long symbol and shift-select a few characters.
You cannot see the selection.
Same problem as with "Highlight all matches".
With the word highlighting code I have in usermacros (using _StreamMarkerAdd()), the selection overrides the highlights - much better.
