Author Topic: Can't change backup location option  (Read 653 times)
tim_k
  • Hero Points: 11
  • -Tim
« on: August 21, 2018, 03:36:23 pm »
I'm tying to change the backup location and in the options/File Options/Backup area, the "Backup Location" field is not selectable. The help hints at the bottom indicate that I should have at least the options of "Global directory" or "Global nested directories". I do not have any options, the field is blank and I can't change it. The "Make backup files" option is set to "Create backup history on save" I can set the "backup directory path" but not the location option.
I get the same behavior on Linux & Mac. SE V22.0.2.1, Hotfixes hotfix_se2202_1, _2, _11
Tim
  • Hero Points: 419
Re: Can't change backup location option
« Reply #1 on: August 21, 2018, 06:25:39 pm »
The Backup location field is only enabled when "Make backup files" is set to "Create backup file on first save".
