Author Topic: Saving files from compressed archives  (Read 981 times)
  • Hero Points: 192
« on: August 21, 2018, 09:43:40 pm »
When I have a file like c:\temp\foo.zip\bar.txt open and then I try to save it, Slick gives some error dialog that isn't so helpful.
How about when I attempt to save, slick should redirect to SaveAs instead of giving an error?
The saveas should default to the parent directory of the archive itself.
Better of course would be to allow saving into the archive, but I assume that doing this is harder and may not be wanted.
  • Hero Points: 460
Re: Saving files from compressed archives
« Reply #1 on: August 22, 2018, 01:39:19 am »
Saving back to the zip file would be cool. Doable but very hard. Your suggestions are very good.
