Author Topic: B2: Bad C syntax indent  (Read 1055 times)
jc44
  • Hero Points: 18
« on: August 22, 2018, 02:20:06 pm »
If I have multilevel braceless blocks then the syntax indent only goes back one level at then end rather than going back all levels, thus:
void fn()
   int i,j;
   for (i = 0; i != 4; ++i)
      for (j = 0; j != 4; ++j)
         printf("Hello world\n");
      // Bad indent
Pretty sure this worked previously
Thanks
John Cox
  • Hero Points: 460
Re: B2: Bad C syntax indent
« Reply #1 on: August 23, 2018, 12:37:44 pm »
I think we can fix this.
There are some other cases which are much harder but not this one. An if then clause may be followed by an else and there there's no way to know whether the user plan's to type an else or not.
jc44
  • Hero Points: 18
« Reply #2 on: August 23, 2018, 01:01:40 pm »
True but I think I would expect you to deal with that in a similar way to the way you deal with case statements in switches - assume no "else" and reindent after the user has typed it.
  • Hero Points: 460
« Reply #3 on: August 23, 2018, 01:45:56 pm »
That works
  • Hero Points: 460
« Reply #4 on: August 23, 2018, 08:36:42 pm »
Fixed for beta 3
