Author Topic: Windows 10 CMD prompt, colors  (Read 1061 times)
  • Hero Points: 189
« on: August 23, 2018, 07:03:16 pm »
Windows 10 CMD prompt now supports "<esc>[xxm" sequences for colors.
Slick "build" window doesn't like this.
I have this env-var set: prompt=$E[91m$p$g$E[0m
In the slick build window, I get a prompt like this:
C:\>cd temp
C:\Temp>
Ugly.
The Slick cmd prompt should support colors, or at least strip out these sequences.
  • Hero Points: 446
Re: Windows 10 CMD prompt, colors
« Reply #2 on: August 23, 2018, 08:46:11 pm »
Beta 3 will temporarily modify the PROMPT environment variable if there are escapes in it.
Color support would be better though
