Author Topic: Doxygen expansion request  (Read 835 times)
b
  • Hero Points: 26
« on: August 23, 2018, 08:34:18 pm »
SE nicely will expand a newly created Javadoc comment if you type /**<return>.  It nicely drops and creates a new Javadoc comment which you can start to type in.
I would like to see something similar for Doxygen (doing the same thing if I type /*!<return>.
[edit]
Tried the above before a typedef.  Noted it worked as desired before a prototype.
« Last Edit: August 23, 2018, 08:41:14 pm by b »
  • Hero Points: 450
Re: Doxygen expansion request
« Reply #1 on: August 23, 2018, 11:57:41 pm »
Fixed to work with typedef for v23 beta3.
