Author Topic: B2: Staggered Java beautification  (Read 814 times)
Marcel
  • Hero Points: 26
« on: August 29, 2018, 05:52:52 pm »
This is probably an old problem, but I just ran across it while playing with the beta.
The attached Java project contains a severely pruned and anonymized source file which, when beautified with the default settings turns into a staircase.
I saved the output file into the project as well.
Re: B2: Staggered Java beautification
« Reply #1 on: August 29, 2018, 06:09:34 pm »
That might be new.  I see what's happened though.  Thanks for the report.
« Reply #2 on: August 29, 2018, 06:45:21 pm »
This will be fixed for beta 4.  And I'm adding that particular file to the unit tests - none of existing unit test source had the right combination of method annotation and nested generics to trigger that bug.
Thanks.
