Author Topic: C beautifier - else & return statements - v22.0.2.1  (Read 3188 times)
JimmieC
  • Hero Points: 17
« on: September 12, 2018, 06:07:27 PM »
I am running the beautifier on a C file. However, I cannot get the results I am looking for. I have found on a previous post that the beautifier does not have settings to put a blank line before if, while, do, & for.
https://community.slickedit.com/index.php/topic,16330.0.html
So, maybe there is no setting for this either. I have attached two files, before & after. Here are couple of snippets with tabs replaced as spaces to hold formatting in the forum text:
    FlashProgram_WIR_routine(address, Data); /* Process routine in RAM */
    ExitCritical();                      /* Enable all low level interrupts */
    if(AccessError())                   /* Is an access error detected ? */
        return ERR_NOTAVAIL;               /* If yes then return the error */
    return Err;
WANT
                         <<--- space here, covered in a previous post though
                           <<--- space here
    return Err;
   else
      setReg(PFIU_PE, 0);                /* Clear Program enable register */
      if(Command == MASS_ERASE)       /* Is the mass erase operation requested? */
      { setReg(PFIU_EE, 0x4000);          /* Write page number and enable intelligent erase */
         setRegBit(PFIU_CNTL, MAS1);      /* If yes, then enable mass erase */
      else setReg(PFIU_EE, (address >> 8) + 0x4000); /* Write page number and enable intelligent erase */
WANT
   else
      else    <<----- statement on same line as else moved underneath else
      }        <<----- if the preceding if for this else had braces, not single-line statement, then wrap braces around block even if single line.
   }                        Or, would be OK to just put single-line statement without braces, if brace checking of prior if proves problematic.
« Last Edit: September 12, 2018, 08:01:37 PM by JimmieC »
JimmieC
  • Hero Points: 17
Re: C beautifier - else & return statements - v22.0.2.1
« Reply #1 on: September 12, 2018, 06:40:47 PM »
There are some other areas of interest as well.
Beautifed file, line 220, mempcpy, beautifier un-indented 3 move instructions
Beautifed file, line 304, WriteWords, need option to use braces on parent for loop if next line is not a single-line
Beautifed file, line 305, WriteWords, braces for if statement are indented
JimmieC
  • Hero Points: 17
« Reply #2 on: September 12, 2018, 06:47:50 PM »
Beautifed file, line 436, FlashProgram_SetByteFlash, want a space between variables & code.
   word Data16;
   byte rot;
                <<------ Want a space here.
    rot = (byte)((Addr % 2) * 8);
JimmieC
  • Hero Points: 17
« Reply #3 on: September 12, 2018, 07:02:14 PM »
Beautifed file, line 261, procflash, code on same line as brace
  • Hero Points: 530
« Reply #4 on: September 12, 2018, 08:27:17 PM »
Please post your user.cfg.xml. That will give us your beautify profile settings. I wasn't able to reproduce this by just changing the "if" brace style.
Your other posts are feature requests. All good ones.
JimmieC
  • Hero Points: 17
« Reply #5 on: September 12, 2018, 08:37:23 PM »
Here is the user.cfg.xml file.
I did dork with the beautify settings a little after I posted to the forum. I don't think I changed anything substantial; Was trying to get rid of the blank line after the opening paren of a function. I changed that setting.
JimmieC
  • Hero Points: 17
« Reply #6 on: September 12, 2018, 08:50:12 PM »
In my earlier post:
This is actually OK. The whole if statement is correctly indented. And, the braces are properly underneath the if. So, cancel this one.
  • Hero Points: 151
« Reply #7 on: September 13, 2018, 02:33:36 PM »
Ok.
I'm debugging the brace without the newline now.  I see what's wrong, and am deciding how to fix it now, so I expect it to be in the next v23 beta drop.
I need to take a closer look at the other features, but it's safe to say any of those would be post v23.0.0.
JimmieC
  • Hero Points: 17
« Reply #8 on: September 13, 2018, 03:18:57 PM »
Yeah, most of the stuff I reported works out to be new features.
Just below the brace without newline, is an else without newline for the single-line statement:
else
 I think that counts a bug too? My comment about optionally wrapping it in braces is a new feature. But, without adding braces, should that be put on a newline at least?
Not a front-burner issue anyway.
  • Hero Points: 151
« Reply #9 on: September 13, 2018, 05:25:04 PM »
You can change the "Unblocked else statement on same line" to Off under Newlines -> 'if' statements for that.   I'd turn off the "Unblocked then statement on the same line" too, for consistency.
  • Hero Points: 151
« Reply #10 on: September 18, 2018, 01:51:12 PM »
Just confirming the fix for the brace without a newline will be in the next drop. Thanks.
