Author Topic: Sync editor file with projects  (Read 5190 times)
paladin
« on: September 14, 2018, 04:05:18 pm »
Is there a way to automatically link the current editor window to the file in the projects space that I am missing? Looking for a behavior similar to eclipse 'link with editor' checkbox.
  • Hero Points: 327
Re: Sync editor file with projects
« Reply #1 on: September 14, 2018, 10:38:34 pm »
Try right click => show file in projects toolwindow.
Is that what you mean?
If so, I used to have some code that would automatically synch the projects toolwindow to the current buffer.  Let me know if that's what you want and I'll see if I can find it.
paladin
« Reply #2 on: September 16, 2018, 09:14:03 pm »
thx for the quick reply... I was familiar with right-click method and should have been clearer. What I was looking for was a 'sicky' - show file in project window - capability that would mimic the eclipse 'link with editor' tooling.
Don't trouble yourself digging through your tool box. If it's not a standard vs capability it's not that big a deal -- just thought I might have overlooked something.
I could be confusing it with another of my support tools but didn't slickedit once have a web repository location for user community submissions for maco's etc. that were 'unsupported' but available to the community?
  • Hero Points: 327
« Reply #3 on: September 17, 2018, 12:56:37 am »
Probably something like this would do it.  This is untested.
void _switchbuf_show_file_in_projects_tb(void)
    show_file_in_projects_tb(true);
User written macros are here
https://community.slickedit.com/index.php/board,21.0.html
  • Hero Points: 327
« Reply #4 on: September 17, 2018, 10:00:56 am »
Don't use the _switchbuf macro - it seems to have some problems.
