Author Topic: C selecting struct member from prompt replaces struct name  (Read 886 times)
namklak
« on: September 25, 2018, 09:14:50 pm »
Hi,
I have a tagged project.  In a C fn when I type the name of a declared struct and type ".", SE correctly lists the members of that struct.  When I select a member, the selected member name replaces the struct name.  This error does not happen in 2017 V22.
  • Hero Points: 438
Re: C selecting struct member from prompt replaces struct name
« Reply #1 on: September 26, 2018, 01:30:57 am »
Was not able to reproduce this easily.  Could you post a small sample?
namklak
« Reply #2 on: September 26, 2018, 07:34:18 pm »
typedef struct
    uint8_t *buff;
    uint8_t len;
}Test_Frame_Buffer_Type;
main()
    Test_Frame_Buffer_Type test_fbt;
    test_fbt
so type a . after test_fbt and the member list pops up. Select a member and test_fbt becomes the member selected.
Thanks
-Namklak
SlickEdit Pro 2018 (v23.0.0.5 64-bit)
Serial number: xxxxxx_BETA
License type: Beta License
License expiration: 2018-10-09 18:00:00
License file: C:\ProgramData\slickedit\23\slickedit.lic
Build Date: September 06, 2018
Emulation: CUA
OS: Windows 10 x64
OS Version: 10.00.0
Memory: 34% Load, 11206MB/32617MB Physical, 11847MB/32617MB Page File, 784MB/134217727MB Virtual
Screen Size: 2560 x 1390
Project Type: Cpp
Language: .c (C/C++)
Encoding: Automatic
Installation Directory: C:\Program Files\SlickEdit Pro 23.0.0 Beta4\ (non-removable drive,NTFS,124734MB free)
Configuration Directory: C:\Users\xxxxxxx\Documents\My SlickEdit Config\23.0.0\ (non-removable drive,NTFS,124734MB free)
Migrated from: C:\Users\xxxxxxx\Documents\My SlickEdit Config\22.0.2\
  • Hero Points: 438
« Reply #3 on: September 26, 2018, 07:38:44 pm »
Still not seeing what you are getting.  Are you able to reproduce this in a default configuration?
vs +new -sc C:\Temp\TestStructConfig
namklak
« Reply #4 on: September 26, 2018, 11:04:50 pm »
Good question - so modifying your command a little to run the correct version of vs...
"C:\Program Files\SlickEdit Pro 23.0.0 Beta4\win\vs.exe" +new -sc c:\temp\teststructconfig
The test code I pasted above does cause the expected response from vs - the selected struct member is inserted after the struct and looks correct: test_fbt.buff
So the plot sickens...
If I go back to my project, which is tagging much of the Nordic nrf5 sdk, FreeRTOS, and just a handful of my files, VS V23 beta still fails the test, and VS V22 works.  And my code builds with gcc with no warnings...
Huh...
at5dapa1
  • Hero Points: 18
« Reply #5 on: September 27, 2018, 05:52:07 am »
I also cannot repeat this issue (tried with v23.0.0.5 64-bit in Win6x64).
Can you post your auto-complete options when you load SE with the profile where it happens?
namklak
« Reply #6 on: September 27, 2018, 02:01:56 pm »
Attached is my auto-complete settings.  I couldn't figure out how to insert the pic into the body of this msg....
The test of VS23 that passed (meaning vs worked correctly) was just opening a file but not adding it to a project.  If I create a new project with just 1 .c file and that code fragment, vs still misbehaves.  So something with projects???
