Author Topic: have to manually rebuild the slick c tag file  (Read 713 times)
  • Hero Points: 322
« on: September 29, 2018, 03:17:12 am »
After upgrading beta4 to beta5 my slick c tag file still had all the beta4 macro files  - so when I do fp save_named_state it takes me to a beta4 source file.  I had to manually rebuild.  Dunno if this is a problem or not.
  • Hero Points: 429
Re: have to manually rebuild the slick c tag file
« Reply #1 on: September 29, 2018, 01:43:10 pm »
This is a beta limitation. It's because the configuration directory version doesn't change. Rebuilding the Slick-C tag file using the Tag Files dialog worked for me.
