Author Topic: Beta 5 does not respect "Show pushed bookmarks"  (Read 13541 times)
asandler
  • Hero Points: 27
« on: September 29, 2018, 08:13:59 PM »
I usually don't like to see a marker when I navigate in the code, so I keep this option disabled. Unfortunately it does not work in v23. Not just in beta 5, in all betas.
I'll appreciate if you can fix it.
  • Hero Points: 535
Re: Beta 5 does not respect "Show pushed bookmarks"
« Reply #1 on: September 30, 2018, 12:33:23 PM »
Please post your user.cfg.xml
asandler
  • Hero Points: 27
« Reply #2 on: October 01, 2018, 04:13:21 PM »
Attached.
  • Hero Points: 535
« Reply #3 on: October 01, 2018, 05:15:42 PM »
Works for me. Hmm..maybe I'm not testing this right. When I do Ctrl+Dot, no bookmark image is placed to the left of the line where I came from. Am I testing the right thing?
  • Hero Points: 521
« Reply #4 on: October 01, 2018, 11:04:42 PM »
Post a screen grab.  Maybe you are seeing another marker type.
asandler
  • Hero Points: 27
« Reply #5 on: October 02, 2018, 12:59:43 AM »
OK. Now that I try to reproduce it, I don't see it anymore. Not sure what the heck is going on. Next time it shows up I will post some screenshots.
asandler
  • Hero Points: 27
« Reply #6 on: October 03, 2018, 12:29:00 PM »
OK. It happened again, on a different computer. Attached is user.cfg.xml from that computer and a screenshot of the bookmark icon.
  • Hero Points: 521
« Reply #7 on: October 03, 2018, 02:09:51 PM »
For any marker in the margin, you can hover the mouse over it and you should get a pop-up explaining it.
In this case, you are looking at a marker for a References search.  To turn off these markers, go to Tools > Options > Context Tagging(R) > References > Highlight references in Editor.
Now for the bad news, I just discovered a bug where turning off the highlight option does not prevent the margin pics being created for references.  So, thanks for catching this, it will be fixed in the next beta drop.
asandler
  • Hero Points: 27
« Reply #8 on: October 03, 2018, 02:23:10 PM »
Yeah, I have this option turned off and see icons anyway.
Thanks
asandler
  • Hero Points: 27
« Reply #9 on: October 22, 2018, 02:55:28 PM »
As of RC2, I still see these icons. What should I do to get rid of them?
  • Hero Points: 521
« Reply #10 on: October 22, 2018, 02:58:54 PM »
asandler
  • Hero Points: 27
« Reply #11 on: October 22, 2018, 07:51:53 PM »
See attached screencast.
  • Hero Points: 521
« Reply #12 on: October 22, 2018, 07:59:59 PM »
Sorry, new option is "Show bitmap for margin for each reference".  This allows you to turn on/off symbol highlighting and the margin bitmaps separately.
Previous sets of reference searches on the references stack will retain the display options that were in effect when they were created, so if you want to clear everything out, you need to clear the references stack.   (Shift+Click on the X icon in the References tool window).
asandler
  • Hero Points: 27
« Reply #13 on: October 22, 2018, 08:39:46 PM »
Much better. Thank you.
