Author Topic: Minimap came back unexpectedly  (Read 1140 times)
  • Hero Points: 325
« on: October 16, 2018, 12:01:21 pm »
I opened up a project I hadn't looked at for a few weeks and the minimap turned up, despite the fact that it's turned off in "all languages".  I had to turn it on in all languages, then turn it off to get rid of it.  I tried opening a few other "old" projects but the minimap didn't come back.
  • Hero Points: 454
Re: Minimap came back unexpectedly
« Reply #1 on: October 16, 2018, 12:41:07 pm »
The minimap can be auto-restored to a setting which is different than your default settings. There is smarts to try not to save an auto-restore setting for the minimap if it matches your setting though but this didn't exist in the earlier betas. I suspect manually turning it off (View>Minimap) will fix this for you.
