Author Topic: Issue with "goto-parent" in a java file  (Read 947 times)
  • Hero Points: 119
« on: October 16, 2018, 04:33:55 pm »
Look for javagotoaparent.tar.gz on support.
When performing "goto-parent" at line 362 of the source file, it takes you to the wrong place. Reproduced this with a clean config, no project/workspace, just load the java file, go to line 362, goto-parent, observe bug.
I'm using RC1 on Linux x64, CentOS 7.2
« Last Edit: October 16, 2018, 04:43:08 pm by rowbearto »
  • Hero Points: 440
Re: Issue with "goto-parent" in a java file
« Reply #1 on: October 18, 2018, 03:04:50 pm »
Good catch, definitely a very old bug.  Was too late for RC2, but can be partially hot-fixed if we do not have to build another release candidate.
