Author Topic: Flickering horizontal scroll bar in search results window  (Read 2381 times)
  • Hero Points: 132
« on: October 16, 2018, 04:42:25 PM »
Look for "flickering-search-scroll-bar.mp4" on support.
In that video, you can see that the horizontal scroll bar in the search results window is flickering. It happens mostly when I click the mouse into a buffer, but sometimes happens when just moving the mouse or not doing anything.
I'm using RC1 on Linux x64, CentOS 7.2
  • Hero Points: 530
Re: Flickering horizontal scroll bar in search results window
« Reply #1 on: October 16, 2018, 08:37:26 PM »
Couldn't reproduce it so far.  Does it matter how big the window is or how many lines are in the search results?
  • Hero Points: 132
« Reply #2 on: October 16, 2018, 09:07:19 PM »
Look for scrollflicker.tar.gz on support.
Needed my 23.0.0 config directory to reproduce, user.cfg.xml was not enough.
Open the java file (no need for project), search for "final" in BigFind. Observe flicker. Same instructions are in the enclosed README file.
  • Hero Points: 132
« Reply #3 on: October 16, 2018, 09:09:25 PM »
I also maximized my SE window if that helps. My screen dimensions (in a VNC session) are: 1920 x 976
  • Hero Points: 530
« Reply #4 on: October 17, 2018, 06:15:43 PM »
Glad you found this one. Thanks for the perfect sample.
Fixed for RC2
