Author Topic: Issue deleting file from Smart Open with date modified shown  (Read 1058 times)
  • Hero Points: 121
« on: October 17, 2018, 12:06:04 am »
Untar attached file.
With a clean config, go to Smart Open, right click at the top and check "Date modified" so that the date modified is showing.
Now go to the directory containing the hi.txt directory. Notice this directory has a date - 181012-1602.
Right click on hi.txt and choose "Delete". It gets the filename wrong in the dialog box, says: "Delete file '.../deletefileissue/181012-1602   2018-10-16T20:00:58hi.txt'". The delete then fails because smart open got the file name wrong.
Similar issue occurs when trying to rename the file. The filename populated in the Move/Rename Files dialog box is not correct.
RC1, Linux x64, CentOs 7.2
  • Hero Points: 453
Re: Issue deleting file from Smart Open with date modified shown
« Reply #1 on: October 17, 2018, 12:55:32 am »
Fixed for RC2. This problem seems to occur with more than just Delete.
