Author Topic: RC2 needs product uninstalled?  (Read 6335 times)
b
  • Hero Points: 26
« on: October 19, 2018, 07:15:51 PM »
Usually I install the beta or the RC and leave the last one installed so that I can quickly back out or compare against the changes.  Once I'm satisfied, I'll uninstall the last rev.   However, with this new RC2, I get error that the current product needs to be uninstalled before installing the new product.   Is this the new norm?
  • Hero Points: 513
Re: RC2 needs product uninstalled?
« Reply #1 on: October 20, 2018, 01:20:19 AM »
Known limitation
If you really want to keep the old installation, make a copy of the entire installation directory somewhere else. Then you can uninstall the old version, and install the new version while still keeping a copy elsewhere. I do this exact process so I can keep copies of various beta/rc versions for testing.
If you're really worried, make a backup copy of your configuration files.
b
  • Hero Points: 26
« Reply #2 on: October 22, 2018, 04:06:13 PM »
I just don't recall having to have had to do this before (at least not for any of the betas).   Thanks for the info.
jc44
  • Hero Points: 22
« Reply #3 on: October 22, 2018, 04:26:48 PM »
Its been like this in all previous SE beta programs; the betas install into separate directories, but the RCs install into the same release directory and so require an uninstall of the previous version to go from one RC to the next.
b
  • Hero Points: 26
« Reply #4 on: October 22, 2018, 04:32:44 PM »
In years past, I was on a Linux platform, so I was always manually typing in where to place the installation so I didn't notice.   This year I'm using the Windows platform, so I did.    Thanks for the clarification Clark and jc44.
