Author Topic: strange clipboard  (Read 4740 times)
  • Hero Points: 342
strange clipboard
« on: October 20, 2018, 07:28:40 AM »
The code below is giving me a strange clipboard.  Put the cursor on append_word_to_clipboard and type Ctrl-C.  The line gets copied to a new clipboard.  Now run the command append_word_to_clipboard and a line gets added to the clipboard but it is prefixed by a light gray right parenthesis character (see attachment) and if you copy the clipboard to a text file the right parenthesis comes too, in column 1.  If I turn off "view other control characters" it changes to a small question mark in a box.  The status bar shows its value as 0A  - linefeed.
Same thing happens if I select a word and type C-S-C append-to-clipboard.
The left-hand window of the clipboard tool-window also goes into some kind of double spacing mode - see attachment.
_command void append_word_to_clipboard() name_info(',')
   select_whole_word();
   append_to_clipboard();
  • Hero Points: 514
Re: strange clipboard
« Reply #1 on: October 22, 2018, 12:37:22 AM »
Fixed in RC3
append_to_clipboard is incorrectly adding newlines between appended clipboards (def_append_clipboard_adds_newline)
